So i would like to build a gaming and 3d modelling pc for around 1500$ to 2000$ Canadian
The pc will be used for mostly gaming with the small amount of solidworks and catia as i already have a workstation laptop for that.
The games I would be playing and already am playing are GTA, Assetto corsa, projectcars, battlefield, ark survival and lots of other f2p games
Some things i do require though is i need to have a I7 CPU and would like something in the lines of gtx 970-980
Also i would like if possible to add in a monitor i already have the other peripherals
Thanks for any help and recommendations ahead of time :)
https://linustechtips.com/topic/403246-1500-cad-build-help/
Ok, 1, those games arent f2p, 2, you dont need an i7 for gaming :P
https://linustechtips.com/topic/403246-1500-cad-build-help/#findComment-5437729
Much ram, much cpu, and some graphics. I do autodesk inventor work on my PC and it works great. 16GB RAM, slightly outdated i5 2500, and an r9 390x.
https://linustechtips.com/topic/403246-1500-cad-build-help/#findComment-5437740
