Hi guys
I recently run into problems with my 2way crossfire setup. They are watercooled and the temps never exceed 60°C.
But it happens - from time to time - that my game just stops and I have to hard reset my pc.
It happened with the following games:
GTA V - Singleplayer
Arma 3 - Multiplayer
Also I've got the feeling, that they don't run as good as they should.
For example: With Battlefield 4, max settings (not ultra) and without MSAA I rarely get 50 FPS. Even though people get at 4k with this kind of setup 60+
They run at stock speeds (957/1250), because if I just oc them a little they start crashing.
My Setup:
2x r9 290
i7 4770
Asrock Z97 Extreme 9
3 Displays with a total of 576x1080
4x2TB WD Black Raid 0
And a couple of Samsung SSD's.
Thanks for your help
PC CPU i7 4770 non K Motherboard Asrock Z97 Extreme 9 RAM 32gb Corsair LP GPU 2x r9 290 Case Phanteks Enthoo Primo Storage 4x2TB WD Black in Raid 0, Samsung 840 EVO 500GB, Samsung 850 EVO 500GB, Samsung 850 PRO 256GB PSU Super Flower Golden Green 1000W Display(s) 3x Asus 24" Full HD Cooling Custom Watercooled, Radiators: 1x 420, 1x 360, 2x 240, 1x120 Keyboard Corsair Vengeance K95 Mouse Mad Catz R.A.T. 7 Notebook Asus UX360UAK (i7 7500U, 8GB Ram, 256GB SSD, 3200x1800 touch, 2 in 1)
https://linustechtips.com/topic/403093-r9-290-crossfire-problems/
Hi guys
My Setup:
2x r9 290
i7 4770
Whats your PSU?
Symptoms you describe lead me to believe it's either a bad PSU (even BAD PSU's still can run things, but crash at random)
Or.. a driver issue/corruption (Download and use DDU) it removed trace files that screw over other driver installs, ensures a clean slate for the driver install.
DDU - Usually fix's performance problems..
Not only should you retry those drivers, but if they have issues, run DDU again, and try an older set.
The fact that you touch the OC slider one bit and it crash's... well thats not a stable system, or one of your GPU's outright is not playing nice.
Can you overclock EACH of them separately?
Have you set PCIE 3.0 in your bios and not left it on AUTO (it could make mistakes and use lower than 3.0/2.0 and if using PCIE 1.0/1.1 on Auto, this could be it)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Totally forgot that.
PSU: 1000w Super Flower Golden Greend. It's a 80+ Gold
Thanks for the hint with the Bios and DDU. I'll try that later and write back.
drivers/crossf issues. welcome to amd
I had two 770 earlier and they weren't much better ;-)
There's a post about AMD's 15.7 Driver being released today. Check it out and see if it fixes your pc issues.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
I tried DDU, clean install of windows and the newest amd 15.7 driver.
Right now it seems to work. OC still isn't possible as desired (max I get is 1025/1300). But I can live with that. Probably just bad luck with my cards.
At least windows stopped crashing.
Thanks for your help :)
