What do you guys use to clean your keyboard and mouse?
Microfiber cloth and water
EDIT: Can of air for keyboard. If you're feeling daring you can take out the keycaps to get it extra clean under there.
https://linustechtips.com/topic/403033-cleaning-peripherals/#findComment-5434429
Soap and water for my keyboard, had to use some turpentine (on an old rag) to get rid of same residue though.
As for mouse: microfiber cloth with cleaning stuff
https://linustechtips.com/topic/403033-cleaning-peripherals/#findComment-5434516
