SSD RAID 0 - Please Help!
Solved by Oshino Shinobu,
You need to set the mode to RAID. Then when booting, hold Ctrl + I (i). That should get you into the RAID setup.
You can then select the RAID mode (Stripe) and add the drives you want.
EDIT: It may be slightly different for your motherboard. (Maybe Ctrl + F for example). Look for any messages when booting, saying pres "xxxxx" to enter RAID/Drive setup.
2
5
thedood2k ·
Posted in Power Supplies3 -
1
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
