Power Color PCS+?
Go to solution Solved by SuperCookie78,
F*** it I'll buy anyways I guess I'll review it too.
I am planning on getting a power color PCS+ r9 380 4gb for my HTPC. I am wondering if the PCS+ cooler is loud. I have read reviews on there previous gen PCS+ on a r9 290 and it cools fine but is loud. I you have any experience with the new cooler or have found a review of the card please reply as soon as possible. http://m.newegg.com/Product/index?itemnumber=N82E16814131673&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&AID=10446076&PID=3938566
LOOK AT MY NEW FLAG DESIGNS FOR PA AND VOTE ON YOUR FAVORITE
LOOK AT MY FIRST BATCH OF DESIGNS HERE
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Cooler Master Seidon 240m
EVGA SuperNOVA 650 G1
Kingston 120gb SSD
SanDisk 480Gb SSD
Seagate 1Tb Hard drive
https://linustechtips.com/topic/401815-power-color-pcs/
+1 though, for a media centre I would think around a 750Ti or 960 should be enough, if you're going for massive 4k and ultra HD media then maybe a 970, but as long as it's not for gaming a 960 or EVGA 750Ti will run a media centre
OP seems to be gaming, so i would still recommend the windforce gtx 960 or other ridiculous cooler
https://linustechtips.com/topic/401815-power-color-pcs/#findComment-5417589
Well I'm also going to game a little(gta v minecraft). It is going to be power my tv and two other monitors . I've tried running three displays off of a gtx 750ti SC and it is not a good time. I just want to know it the cards fans are quite rehab last gen cooler.
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Kingston 120gb SSD
SanDisk 480Gb SSD
https://linustechtips.com/topic/401815-power-color-pcs/#findComment-5417600
I forgot to mention this in it that cooler master elite 110 so 210mm graphics cards are the limit
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Kingston 120gb SSD
SanDisk 480Gb SSD
https://linustechtips.com/topic/401815-power-color-pcs/#findComment-5417623
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Kingston 120gb SSD
SanDisk 480Gb SSD
https://linustechtips.com/topic/401815-power-color-pcs/#findComment-5417706
