Just wondering if the WATERCOOLING ANTEC KÜHLER H2O 1250 fits on this case!
Halp! :D
You're going to have to take out the cable management bracket to make it fit. I would find something smaller.
https://linustechtips.com/topic/401652-watercooling-nzxt-s340/#findComment-5415138
I think it will not be a problem for the cable management bracket, the problem is the length of the tubes no?
The size of the radiator is the problem. The tubes aren't even something I considered.
https://linustechtips.com/topic/401652-watercooling-nzxt-s340/#findComment-5415165
