I have the Netgear C6300 router and I am trying to port forward my Minecraft Server. I have port forwarded the way I usually would on any router but the default port '25565' is said to be unreachable. I have posted a screenshot of the gateway and the application I have used to check the port. The default gateway for my router is 192.168.0.1 and the IPv4 for the server's host is 192.168.0.25. Any help is appreciated, the router is brand new.
post-181907-0-30571200-1436125653_thumb.
post-181907-0-82570800-1436125675_thumb.
post-181907-0-65308900-1436125928_thumb.
https://linustechtips.com/topic/401098-help-with-port-forwarding/
Yeah, let's upload all your IPs to the internet
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
Lol
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Doesent show his external ip so...
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
The port forward configuration appears to be correct. Any external address connecting on port 25565 is forwarded to 192.168.0.25 25565.
Just want to ask, was the Minecraft server running? No service running, no access. Also, if this is a windows machine you will most likely need to create an exception in the firewall allowing external addresses to access port 25565. By default windows does not allow unsolicited incoming connections for obvious security reasons. Also make sure you run the server as administrator, not doing so may also cause windows to restrict assess.
