Hello everyone,
Simple, Clean, Silent is what I'm striving for. This will be my first build ever and I really need advice on...well pretty much everything, thanks in advance   :)
My budget is roughly 2000$ (CAD) including all accessories such as keyboards, monitors, etc.
Uses: Video editing (nothing fancy), Music creation (Cubase and such), Programming, Light gaming
What I have in mind right now is a VERY rough idea of the different components, again since I'm entirely new to this. ALL suggestions are very much appreciated   :D
          CPU: Intel 4770k
          Motherboard: MSI Mpower LGA1150 or ASRock z87 Extreme4 (for the price and color scheme)
          Graphic Card: EVGA GeForce GTX 760 SuperClocked w/ ACX Cooling? (edit)
          Power Supply: XFX Pro 750W Black Edition
          Memory: G.SKILL Sniper Series 2x8GB
          Storage: Interested to see how the Samsung EVO will turn out to be but for now some kind of SSD for a boot drive and Seagate Barracuda 1TB 7200RPM for mass storage
          Case: Fractal Design Arc Midi R2 (edit)
          CPU Cooler: Swiftech H220
          Fans: Scythe Gentle Typhoons
          Keyboard: Ducky or DAS (brown switches)
          Monitors: Asus VE248H? (edit)
          Speakers: ?
          Sound Card: Asus Xonar STX (edit)
> I currently have a pair of audio-technica ATH-M50
I would potentially consider raising my budget but for now it is as it is. The overall color scheme would be dark/black/grey, etc. with some touches of another color such as the yellow accents on the Mpower. I will be sleeving my cables, however I do not include those fees into the budget, suggestions on those are very welcomed as well   :D
THANK YOU   :)
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
https://linustechtips.com/topic/40107-simple-clean-silent-build-suggestions/
If you are truly going for video editing i recommend an IPS panel. Mechanical Keyboards are a MUST. Mice? SteelSeries Sensei or Razer Naga or Deathadder ive heard are great choices.
://www.newegg.com/Product/Product.aspx?Item=N82E16824005419
Monitor I found. Seems nice
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
I'd say:
Seasonic M12II 520 Watt since your current PSU is overkill
Dell 24 or 27" IPS panel
ASUS Xonar STX/ST sound card.
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
Up the gpu and get a asus ve248h monitor. Sound card, get the best asus one for you budget.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
If you could I would recommend getting the Corsair Vengeance RAM, link here: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233299
That is just my opinion though :P
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
I've been meaning to go IPS  :) However at that price aren't I better off with something like a PB238Q from Asus? I'm not looking specifically for a mouse right now but I'll keep that in mind!
I'd say:
Is a 520W power supply enough for future upgrades in say 4 years? Since the price difference is about 30-40$ I'll be willing to pay more just in case I add more power hungry components in the future. I've been thinking of the Xonar STX but I'm not sure if it'll fit in my budget. I'll certainly look more into it.
The VE248H does look really nice! Do you happen to know how are the viewing angles for it?
I've thought of it however I've heard Slick say a few times how the bandwidth would affect performance of VM's and programming related stuff which is why i went for an 1866 kit instead of a 1600, correct me if I'm totally wrong though ahaha  :P They do look amazing though!
@kcchi no, but it is my monitor, I have three! I like them, they were inexpensive and preform great for me! I think the viewing angles are good.
Awesome, I'll keep that in mind! Thanks  :)
If you don't like the door on the R4, then the arc midi R2 might be the case for you? As for the fans maybe you should consider the noiseblocker e-loop's.
CPU: i5 4670K, Mobo: Gigabyte Z87X-UD3H, RAM: Corsair Vengeance Pro 8GB, GPU: Asus 280X, Case: Fractal Design XLR2, SSD: 840 evo 120GB, HDD: 2x 1TB Seagate, PSU: Corsair RM750, Cooler: Cooler Master Hyper 212 evo
Take a look at my signature for the PC Planning Guide.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
Yes, I've been looking into the arc midi R2 just today! Beautiful case, not as quiet as the R4 but I'll try to make up for it with other components. I've never heard of the noiseblocker fans, they do seem interesting; I'll take a closer look at them, thanks for the suggestion!  :)
Awesome, thank you very much! I'll take a close look at it  :)
Just FYI, all-in-one cpu liquid-cooling loops aren't very silent when compared to high-end air coolers.  The fans have to spin faster to get the air through the radiator, whereas the air coolers can spin slower since the fins are spaced further apart.  I don't know how well the Define R4 can block that noise but that's been my experience.
"The doctors X-rayed my head and found nothing."  - Dizzy Dean
i7-4770K, ASUS Z87 Gryphon, EVGA GTX 780 Ti, 16 GB Kingston Fury RAM, Crucial M500 240 GB, 1TB Seagate Barracuda, Cooler Master Hyper 212 Evo, Seasonic 760W PSU, Asus BD, Phanteks Evlolv mATX (Gunmetal).
I've actually never thought of that, thanks! I'll be looking more into it, any suggestions perhaps?
I've probably got a few suggestions to make but before that, I've got a question. What video editing program(s) do you use?
I'm currently using Sony Vegas Pro 10; it's quite capable of doing what I need to do. Never really took a close look at Premiere but maybe I should..
Recommendations: http://ca.pcpartpicker.com/p/1ngdk
Crossfire ready.
You might want to think about dropping the H220 for a cheaper cooler if you aren't too keen on getting high overclocks. The price/performance ratio tends to drop off for overclocking the instant you get an aftermarket cooler. This is not always the case but it applies for your scenario.
Crossfire ready.
This looks great, thanks! I might look into more motherboards since the brown pcb on asrock's extreme z87 is bothering me more than it should..I'm also not quite fond of AMD since the frame rating issues but I'll definitely keep it in mind. Aside from that, it looks pretty good  :) thanks again
Well AMD's new 13.8 drivers came out several hours ago that have made things better.
I was not aware of that, awesome! Thanks
