Alright, for the past two days I've had such huge memory usage by doing NOTHING it's been hell. I use Chrome and I recently downloaded Firefox. First I noticed how I was using 3.91GB while just browsing Chrome with a couple tabs on. I restarted my computer and downloaded Firefox, I browsed 30 minutes and my memory usage went to 2.20GB then soon to 3.61GB. At this point I suspect there's something wrong with MY phyisical RAM memory modules? I don't know. I closed Firefox and still my memory usage was this: post-169964-0-09799800-1436093901_thumb.
What do I do? Do I switch to Internet Explorer? I'm afraid this doesn't seem like an internet browser issue and more of a case of old-ass worn out RAM. I just reinstalled my Windows, fully formatted everything, and while I reckon a new install would probably fix this I am not going to go that route.
What do you think?
https://linustechtips.com/topic/400861-huge-effin-memory-leak/
CHROME!!!!!! memory leak. Just use Internet Explorer 11, simply the best ~
CPU: Intel Core i7 5960X @4GHz cooled by a Corsair H110i GT | MBO: Asus X99 Sabertooth | RAM: Crucial Ballistix Sport 32GB DDR4 (4x8GB 2400MHz) | GPU: Gigabyte G1 Gaming GTX 980 | SSD: Samsung SM951 M.2 SSD | HDD: 1TB Western Digital Black Drive | PSU: Corsair HX750i | Case: Corsair Obsidian 450D
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403632
Well Chrome isn't what's eating all your memory. That's a pretty normal level of RAM in use though, perhaps get another 4GB module?
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403637
Alright, for the past two days I've had such huge memory usage by doing NOTHING it's been hell. I use Chrome and I recently downloaded Firefox. First I noticed how I was using 3.91GB while just browsing Chrome with a couple tabs on. I restarted my computer and downloaded Firefox, I browsed 30 minutes and my memory usage went to 2.20GB then soon to 3.61GB. At this point I suspect there's something wrong with MY phyisical RAM memory modules? I don't know. I closed Firefox and still my memory usage was this: process.png
What do you think?
That's what a memory leak does.
Even though the program (I.e. Firefox) is closed, the OS still thinks all the memory is being used. Your only option is to restart your computer.
Have a look at Linus' TechQuickie video regarding to memory leak.
Chrome (tabs) simply uses up a lot of resources when open, but will clear once you close them.
FireFox has had a memory leak issue for a loooong time, and it is taking a while for them to find exactly where the problem lies.in their coding.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403644
Even though the program (I.e.) is closed, the OS still thinks all the memory is being used. Your only option is to restart your computer.
I did watch the video. That's what caused me to restart my PC everytime I sensed something is wrong.
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403651
Yeah, because taking longer to load a webpage is great, and who can forget its AMAZING UI?
/s
I wasn't actually joking there, I did a few benchmarks on IE11, it WILL actually beat Chrome in debugs...on a 5960X.
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403659
Few years ago when my HDD ( Windows was on it ) was dying I had the same issue. Two weeks later my HDD died and after getting a new drive problem vanished.
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5403757
When I did page loading tests, FF blew IE 11 outta the water
Aha, Debug tests =/= Loading ;)
https://linustechtips.com/topic/400861-huge-effin-memory-leak/#findComment-5409880
