Hello there!
(I'm not sure whether to put this here in "Cases and Power Supplies" or "Graphics Cards", so I put it here!)
I am in needed of deciding what graphics card solution will do well with a SeaSonic G-Series 550 W Power Supply!
  • A card that will do well over a long period of time
  • A card that will not deteriorate other components due to its power usage.
  • A decent card for E-Sports games etc (LoL, CSGO, DOTA) and light usage of titles such as Far Cry, Skyrim etc.
Thanks for the help guys, really appreciate it!   :)
https://linustechtips.com/topic/400767-help-needed/
Hello there!
a 960 look good for that, what res are you going to play??
PC Specs: Case Corsair Vengeance C70 - CPU i7-4770K @3.5Ghz - MOBO Gigabyte Z87X-UD3H - RAM HyperX Fury 2x8GB @1600Mhz - GPU MSI VENTUS RTX 2080 SUPER - HDD Seagate Barracuda ST1000DM003 1TB, Toshiba DT01ACA100 1TB, WD Black 4TB - PSU EVGA 750 G2 - Display Samsung S22C150 - CPU Cooler CM 212 Hyper EVO - Mouse Steelseries Sensei 310 - Current Wattage by pcpartpicker: 387W.
https://linustechtips.com/topic/400767-help-needed/#findComment-5402745
Sorry I couldn't get back to you guys fast enough!
what's your budget? since australia has insane prices, we really need to know this x]
My budget is $1700 AUD. I have already purchased the power supply and the case!
1920x1080 Res using a 144hz monitor!
Probably should go in GPU sections.
As for what GPU what's your budget and current system spec.
This is my build-
Fractal Design R5
i5 4690k
Asus Z97-a
Hyper X Savage 240GB SSD
HyperX Savage 16 GB RAM
WD Black 1TB
BenQ XL2420G
Noctua Nh-D15
And the aforementioned power supply!
https://linustechtips.com/topic/400767-help-needed/#findComment-5402864
Alright thanks!
I know this might seem a little lazy, but can anyone find the listed TDP's of most popular graphics cards?
Thanks again!
Here you go sir:
GeForce GTX 750 Ti - 60W
GeForce GTX 960 - 120W
GeForce GTX 970 -  145W
GeForce GTX 980 - 165W
Radeon R9 285/380 - 190W
Radeon R9 280X - 250W
GeForce GTX 980 Ti - 250W
Radeon R9 290/390 - 275W
Radeon R9 390X - 275W
Radeon R9 290X - 290W
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/400767-help-needed/#findComment-5403827
Alright thanks!
Thanks again!
That Seasonic psu will handle pretty much any single graphics card.
I agree with W-L that a GTX 970 would be a good choice for that resolution.
https://linustechtips.com/topic/400767-help-needed/#findComment-5405119
Alright thanks!
Thanks again!
then a 970 is good for you
https://linustechtips.com/topic/400767-help-needed/#findComment-5406041
