Ram compatibility, questions, help!
By
acercon
in Troubleshooting
in Troubleshooting
Solved by slightlyjaded,
oh, thank you for doing that! so theses will work as well right? ( http://www.ncix.com/detail/adata-xpg-v1-0-8gb-ddr3-1600-45-93607-1382.htm)
yup, same speed, same timing.... different manufacturer (it doesn't matter as much as it used to) Be aware if you try pushing your ram past what it's rated for you may run into issues.
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab0 -
1
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning15 -
1
3
play_circle_filled
Latest From ShortCircuit:
