Ethernet Speed PLZ Help
Go to solution Solved by Jamdude,
When i open the dropdown for Network Adapters it says Realtek PCIe FE Family controler?
I think the FE stands for Fast Ethernet which is 10/100Mb/s shown here: http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PNid=7&PFid=10&Level=3&Conn=2
I have recently decided to upgrade my modem and router from 10/100Mbit to Gigabit, however I am unsure on how to check to see if my laptop has a full speed Gigabit port. I would really like to know how to check within windows 7 itself rather than checking with the manufacture. Could someone please help so i can see if its worth upgrading or not. Thanks
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/
Press Start then type Device Manager, then in Device Manager go to Network Adapters and it should say something along the lines of Gigabit Network Connection if your laptop supports Gigabit Ethernet.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517053
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517083
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517095
Oh well thank you verry much i am saving up for a desktop pc so then ill have full gigabit connectivity and ill upgrade my network at a later date instead of wasting my money now, again thank you
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517110
Not a problem.  I don't know where you get components from in NZ but you could always et something like this: http://www.amazon.co.uk/StarTech-com-Gigabit-Ethernet-Network-Adapter/dp/B0000TO0BQ/ref=sr_1_1?ie=UTF8&qid=1374929389&sr=8-1&keywords=gigabit+ethernet
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517127
Yeah i need to find a way to get all my pc parts to nz including a network card, the prices here are high and the stock is low it sucks
https://linustechtips.com/topic/40025-ethernet-speed-plz-help/#findComment-517160
