So I was just about to do some sound testing on my machine with a crude iPhone app which tells me the dB level. When I started up Unigine Valley and took the side panel off, I started hearing an odd buzzing noise. I turned all of the fans off but the buzzing was still there. When I Alt+Tab'd out of the program, the buzzing stopped. During the black frames between scenes in Valley, the buzzing also stopped. Under intensive graphical load, the system appears to buzz. I think it might be my graphics card, but I'm not entirely sure.
Anybody have an idea?
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/399802-odd-buzzing-noise/
This is called coil whine. it is perfectly normal. running a very intensive application for three days can fix it. If you want to, blow a desk fan into the card with its fans maxed and run folding@home for a couple days.
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389096
It's likely coil whine which usually occurs under significant loads, but sometimes it can happen during certain rendering scenes or workloads(Example: Transferring files over a network could induce coil whine in some systems).
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389134
Likely coilwhine, as stated before. A normal occurrence when the gpu is under load, or outputting very high framerates like 500+ fps, but I wish it wasent...
It can be better in some cards than others, and once you have it, nothing shy of changing the PSU will change it...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389139
From what I've read, coil whine is a high pitched whine. This is definitely not a high pitched whine, it's a buzz.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389164
It can be different frequencies. It is almost certainly coil whine, but it... COULD be the PSU with a poor voltage regulation.
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389184
Coil whine can come in all forms, including buzzing. It doesn't have to be high pitched, but that is the general tendency.
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389189
Don't know if it happens all that often to EVGA cards, but I use an EVGA GTX 970 SSC. My PSU is also an EVGA 650GS.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389197
Is there a video on this? It seems very bizarre.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389314
Tedster linked to a video about it:
Coil whine?
QUOTE when replying to others / Quality over Quantity in your posts / Avoid ambiguous topic titles
Desktop: "Shockwave" Core i7-5820K / GTX 970 SSC / ASUS X99 Deluxe / 16GB DDR4 / 120GB Samsung 850 EVO / 2TB WD Black Caviar
Laptop:  "Archippos"  Dell XPS 15:  Core i7-7700HQ  /  GTX 1050  /  16GB DDR4  /  512GB NVMe PCI-E SSD
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5389987
I meant the fix, running an intensive application for 3 days straight.
Has anyone tried this in an attempt to stop coil whine?
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5390069
Coilwhine varies. For me it is also more of a low pitched buzz.
The high pitched noise is more to do with the very high framerates, and the lower pitched buzz tends to occur when you are running at reasonable frequencies, but under a heavy load
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5390223
I personally havent tried, but I have used the card for quite some time now and the buzz hasent changed, and 3 days seems like an oddly specific point...
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5390244
I have fixed/reduced coil whine running f@h for 3 days. I have also suggested it to someone else and it worked for them.
Awesome!
I download F@H yesterday and have been folding all through the night. :)
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/399802-odd-buzzing-noise/#findComment-5394552
