Hey everyone, good to see you here.
I want to buy a new laptop and replace my Asus 1215b.
So, i have very thight budget and can't order anything from online shop (sadly) and i hope you understand with my condition.
What for?
1. Internet, writing, and daily use
2. Online gaming (World of Tanks, World of Warship,etc)
3. Offline gaming (don't have any idea but 720p in low is okay)
And what you get, Boy?
1. ASUS X550DP
AMD A8 5550m 2.1 GHz
Radeon HD 8670m 2 GB
500 GB HDD
2GB DDR3L RAM (and will upgrade it to 8 gb dual channel if it possible to remove 2gb)
2. Dell Inspiron 14 3458
Intel Core i3 4005u 1.7 GHz
nVidia Geforce 820m 2GB
500 GB HDD
4GB DDR3L RAM (upgrade this too)
-[doesn't have usb 3.0]
3. ASUS X455LD
Intel Core i3 4030u 1.9 GHz
500 GB HDD
2GB DDR3L RAM (and this too)
Yeah, i am in low budget xD Thank's for you advice!
https://linustechtips.com/topic/399750-help-choosing-laptop/
Hey everyone, good to see you here. I want to buy a new laptop and replace my Asus 1215b. So, i have very thight budget and can't order anything from online shop (sadly) and i hope you understand with my condition. What for? 1. Internet, writing, and daily use 2. Online gaming (World of Tanks, World of Warship,etc) 3. Offline gaming (don't have any idea but 720p in low is okay) And what you get, Boy? 1. ASUS X550DP AMD A8 5550m 2.1 GHz Radeon HD 8670m 2 GB 500 GB HDD 2GB DDR3L RAM (and will upgrade it to 8 gb dual channel if it possible to remove 2gb) 2. Dell Inspiron 14 3458 Intel Core i3 4005u 1.7 GHz nVidia Geforce 820m 2GB 500 GB HDD 4GB DDR3L RAM (upgrade this too) -[doesn't have usb 3.0] 3. ASUS X455LD Intel Core i3 4030u 1.9 GHz nVidia Geforce 820m 2GB 500 GB HDD 2GB DDR3L RAM (and this too) Yeah, i am in low budget xD Thank's for you advice!
from the specs, i'd decide between 1 and 3, don't know how good amds laptop gpus and cpu (or is it actually a apu?) are so i'd prefer 3 and upgrade the ram
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/399750-help-choosing-laptop/#findComment-5388310
This text is begging for a few "enter\return" key presses..
out of these 3.. number 3 + ram
https://linustechtips.com/topic/399750-help-choosing-laptop/#findComment-5388317
I try enter it and when i post it, it turn to disaster. I will fix it soon
Im pretty sure most if not all of these laptops have an empty sodimm slot with the original 2gb being soldered on the motherboard
the x550 maybe have 2 removable sodimms cus its bigger. but the other two most probbaly its a soldered 2gb ram.
Are you by any chance in india?
https://linustechtips.com/topic/399750-help-choosing-laptop/#findComment-5388386
I recommend the ASUS X455LD
Thanks for your advice :D
X455ld is soldered 2gb ram. I know from it's forum dunno about the dell one.
"Are you by any chance in India?"
Well no. I am from Indonesia :D
https://linustechtips.com/topic/399750-help-choosing-laptop/#findComment-5388489
