H100i thermal compound?
Go to solution Solved by Hirad123,
the stock one is fine
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515568
with arctic mx4 or any dedicated tim you can get up to 5 °C lowr temps
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515571
It will be a few degrees. I would just use what comes with the H100i
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515577
No you wont. Going from the worst to best TIM if properly applied there is only a 3c difference. The H100i's TIM is very well applied and is high end stuff. only about a 1-2c increase MAX.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515613
just telling my experience, dude. and if I say I got a 5°C difference with an 4.6GHz (1.3V) 3770k, thats it
Noiseblocker eloop fans
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515624
I have no complaints about the stock compound its generously preapplied and performs within a few degrees of leading compounds or paste.
PC Specs: CPU: Intel i7 4770K / CPU COOLER: Corsair H100i / Storage: Samsung 840 EVO 120Gig and Seagate Barracuda 1Tb / Motherboard: MSI Z97 Gaming-7 / GPU: EVGA GTX 780 SC ACX / Power Supply: SeaSonic M12II 850watt / Case: Corsair 750D 680 Coaster
https://linustechtips.com/topic/39932-h100i-thermal-compound/#findComment-515938
