First pc build
Go to solution Solved by Dzzope,
can you tell me if its a good build:
Intel core i5 4690k 3.5Ghz 6MB box lga1150
corsair cooling hydro series H100i GTX
msi z97 s sli plus
CORSAIR Vengeance Pro CMY8GX3M2A1866C9B (8GB Ddr3)
asus strix gtx 960 2gb gddr5
KINGSTON HyperX FURY 120GB for windows
wd 1tb 64M/s600 GreenPower
corsair cx600 power suply
all housed in a fractal design define s black window
I'm thinking about to add a CRUCIAL BX100 500GB in the future
Also I already have the power supply and graphics card.
I'm going to use this pc for gaming like gta 5 on max/ultra settings but i know thats not going to be the case whit this gpu and later on im going to add a nother graphic card and liguid cool the gpu and cpu.
sorry for my bad english thanks for the help  :)
Follow your own topics.. Gives notifications of all replies to the thread.
CX600 isn't great but you already have it so meh,
Ram speed means very little, get the cheapest set of 1600 cl9 that fits your build for aesthetics.
Don't spend too much on the motherboard.. about 50% more than the cheapest z97 is about the sweet spot.
Unless your getting a really good price on the hyperX fury, just go for a Samsung 850 Evo or OCZ arc 100, usually very cheap and really good performance.
Stay away from WD green HDD's unless it's only for media storage and the like... don't have applications installed on it.
If you can save else-where, get a 970 instead of the 960.. Even if you have to go with a cheap air cooler on the processor or stay on stock for a while.. GPU will make more of a difference to that build than anything else.
msi z97 s sli plus
https://linustechtips.com/topic/398972-first-pc-build/
Looks good! :D
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376920
can you tell me if its a good build:Intel core i5 4690k 3.5Ghz 6MB box lga1150corsair cooling hydro series H100i GTXmsi z97 s sli plusCORSAIR Vengeance Pro CMY8GX3M2A1866C9B (8GB Ddr3)asus strix gtx 960 2gb gddr5KINGSTON HyperX FURY 120GB for windowswd 1tb 64M/s600 GreenPowercorsair cx600 power suplyall housed in a fractal design define s black window
Also I already have the power supply and graphics card.I'm going to use this pc for gaming like gta 5 on max/ultra settings but i know thats not going to be the case whit this gpu and later on im going to add a nother graphic card and liguid cool the gpu and cpu.sorry for my bad english thanks for the help  :)
Please put this in PCPartPicker, also currency and budget on this?
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376929
dont go for the 960, its poop $ per FPS, save up to a 970 or get an amd card, i dont have any suggestions for amd cards but someone will tell you a good one. also 600W is way to much power go for 450-500 ish wat
Builds:
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376937
There's never too much power...unless you have a 1500 watt... Don't change your PSU, you can always have the extra headroom for overclocking or another graphics card.
PC Interest - Thriving | Wallet Status - Near Empty
Ryzen 9 5900X, ASUS TUF RTX 4080
Corsair Vengeance LPX (2 x 16GB) 3600MHz, ROG Crosshair VIII Dark Hero
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376964
i just think he can save some money on the PSU
Builds:
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376982
Learn to read, he already has the GPU.
Echelon Mk 2.11
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5376990
no need to be rude about it, either he added that part after i read the post or i just missed it
Builds:
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377011
Yeah there are fully modular 750W EVGA PSUs for around the same price, so it's a little more bang for the buck, and I've heard elsewhere on this forum that CX series aren't exactly the most reliable, could be pulling that info from where the sun don't shine though.
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377012
yep but i already got a psu so thats not worrying me, for now its ben a god power supply didn't do nothing wrong
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377071
 https://pcpartpicker.com/parts/partlist/
curency is euro the budget is 1300€
Could you provide us with the permalink instead of the browser link? We can only see it if you do that.
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377099
msi z97 s sli plus
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377132
If you can save else-where, get a 970 instead of the 960.. Even if you have to go with a cheap airarrow-10x10.png cooler on the processor or stay on stock for a while.. GPU will make more of a difference to that build than anything else.
For the graphic card I can't change it unless I sell it and buy a 970 probably gonna do that in the future before water cooling it
and i'll stick with the stock cpu cooler for now.
for the ram I can go with corsair vengeance pro cmy8gx3m2a1600c9b 8gb
For the mother board I don't know this one offers me sli for the future and the color is in my theme
Im geting a great deal for the hyperX fury the samsung 850 evo and OCZ arc 100 are to expensive in my country
for the HDD whats your solution should i go whit a  WD blue edition?
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377348
Then don't make the original poster feel bad with his purchase by saying the 960 is "poop $ per FPS". It might not be the best price to performance GPU but it is still one hell of a GPU that is very capable.
Echelon Mk 2.11
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5377893
Check this site for good price comparisons in EU..
http://tweakers.net/
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5378169
I did comparisons of different pc retailers and this on that i'm buying from has the most parts and its not that expensive than the others
I even looked in austria but the shipment price is to big
thanks for sharing the link  :D
https://linustechtips.com/topic/398972-first-pc-build/#findComment-5378717
