NZXT s340 case, what fans are better suited SP or AF for front Intake?
Solved by MeltingPoint,
Which ones would you suggest if I got the Venturi, Static pressure or air flow for the front intake?
I always use static pressure optimized fans whether its for coolers or case ventilation. Its a misconception that SP fans do not have good airflow. They might be even better because they have to move air though fan grills, filters and whatnot.
Featured Topics
alexfic ·
Posted in New Builds and Planning3 -
1
BryanOttawaDetroit ·
Posted in General Discussion1 -
2
2
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion6 -
9
jordan_wills ·
Posted in New Builds and Planning2
