Ax760 guide?
Solved by Hunter7263,
I have no idea where to put the cables. If someone has the same PSU could you take a picture and show me? I think the problem is the motherboard cable, it has 2 pieces on one end the only one of them fits in the psu, also where do I plug the gpu cable?
Honestly you just have to look at the back of the power supply. It tells you what the slots are for. The rest of it is just matching holes like we did as toddlers except slightly more complicated. They mobo 24 pin goes into the motherboard but it splits into 2 for the power supply. If the cable doesn't fit its not the right one.
