Hello,
I am not sure where to post this, but I think it belongs over here.
So, it is around 25 ºC in my room (77 ºF) and when I am gaming my laptop is running really hot, I can't even touch it for more than 10 seconds. When I am gaming, my CPU (i3 3227U, I am using the iGPU) passes 80 ºC when it's at 90% load. I think I'm also noticing some thermal throttling.
Should I worry, and can I do anything about it?
I don't want to buy laptop cooling pads because I am saving money for a new pc.
Thanks in advance,
MrChavelo
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/398024-cpu-temperature/
Laptop <-- This.
How are your fans doing? Spinning like crazy?
When I am gaming, yes, really loud
Project Pluto
https://linustechtips.com/topic/398024-cpu-temperature/#findComment-5365728
That's just a limitation of a laptop and the cooling system. IT will run hot and the fans will whine because they need to work overtime to cool the CPU.. Not much that can be done..
1. Keep it on a flat surface
2. Put a fan next to it xD
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/398024-cpu-temperature/#findComment-5365736
I was hitting similar temps on my Asus G50vt, which ran a Core 2 Duo @ 2.14GHz, and a 512MB GTX 9800m. The thing was quite the work horse...
It eventually died not from heat exhaustion, but from inadequacy (and a dead display...).  :(
"A picture is starting to form here... I wonder if it's accurate? Some pieces don't quite seem to fit. Or maybe I just don't like the way it looks."
https://linustechtips.com/topic/398024-cpu-temperature/#findComment-5365771
