Hello all!
I'm currently saving some extra money to replace the stock fans in my Corsair 500R. I want to replace the 2 120 mm fans in the front with fans that have those led rings around them. Airflow must be decent of course.
For the 200 mm fan I just want one that doesn't vibrate like crazy and is a little more silent overall. Don't want any leds on this one.
Can anyone recommend me some fans that meet my requirements?
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/397593-fan-suggestions/
Hello all!
I think Thermaltake has some LedRing fans, not sure. And Aerocool uses 200mm silent fans in their cases, but I don't know if they sell them specifically.
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/397593-fan-suggestions/#findComment-5360533
Hello all!
the front fans you are thinking of are Thermaltake Riing fans and a good 200mm fan is the NZXT FS-200, hope this helps.
https://linustechtips.com/topic/397593-fan-suggestions/#findComment-5361380
