I want to switch out my G15 for something mechanical, but the question is what type of key I should get.
I want something that's easy to type on, I do not play games as much as before, and now I type a lot more.
I've tried MX reds and personally I do not like them.
I know going for MX Browns or Blue's are good for typing, any input?
MEH
https://linustechtips.com/topic/397-choosing-between-mx-keys/
I decided buying a mechanical keyboard based on Linus videos...I've never tried mechanical keys before...so I just thought I do like my keys to be clicky and I want to feel the actuation point....what I'm trying to say is: I just thought what do I want to have and then I decided to buy a Razer Black Widow 2013 Edition (MX Blue)...never tested it and now I don't want to miss it it feels AWSOME!!! So I would say think about what do I want to have and then buy it online....and if you don't like it you can still send it back!
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-4352
In addition here's a keyboard guide I found very helpful...there's also a comparison between the different switches....
http://www.overclock.net/t/491752/mechanical-keyboard-guide
I used to have a website in my favorites with the diagrams of the different switches but I can'r find it...but it was also very helpful...
diagram mx blue:
http://www.daskeyboard.com/model-s-ultimate/
diagram mx brown:
http://www.daskeyboard.com/blog/?page_id=1458
diagram mx black:
cpuldn't find one for the black ones and the red ones you didn't like anyway so GOOD LUCK!!! Enjoy your new keyboard!
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-4419
The CoolerMaster Quickfire TK cherry mx blue is a pretty good mechanical keyboard. It's pretty beast for the price. The backlight is amazing too.
http://us.ncix.com/products/?sku=77976&vpn=SGK-4020GKCL1&manufacture=COOLERMASTER
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-7205
I did read something about that' date=' also the blue's (from my experience) are much easier to find. Is this true?[/quote']
Not really. I think all of them (between Blue, Red, Brown, Black) are all pretty common. It all comes down to what kind of keyboard you want in terms of features,
most of them come out pretty basic and minimal.
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-7379
Read this, pretty much covers it all. Reds imho tend to be the hardest to find, as there are very few people that use them, i myself use blacks, as they are a nice on a gaming, but it really comes down to personal preference, if you know someone with a mechanical keyboard go have a try of it, if not i am sure your local e-tailer would be more then happy to let you test out each switch.
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8173
I have 2 mechanical keyboards at the moment and these 2 keyboards are the only ones that I've tried yet, Razer Blackwidow with blue switches and a Ducky DK1087 that has green alps switches. I've been using my blackwidow lately because I can't live without a numpad and I love the sound they make every time I press on them, although the difference from blue switches and green alps switches are noticeable. Green alps are louder I think because the keys rattles every time you press on them, and they are much more stiff than the blue switches although they are both clicky in the same way.
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8232
How much are you willing to spend on the keyboard?
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8293
I just recently got the Logitech G710+ and it uses Cherry MX browns and although I like the clicky sound of blues I rly like the design of this keyboard. As well browns are not silent, they are far from it they still make a lot of noise, not as much as blues, but it is good when you want the click but don't rly want to have ppl stare at you for typing to loud.
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8491
General Summary of Switches
Common switches are the reds, blacks, blue and browns
Both blacks and reds are linear switches with no feel of when the actuation point is. Blues and browns are tactile switches where you can feel the actuation point of the key.
Black switches are red switches that are slightly heavier. Blue switches are slightly heaver than browns.
Blue switches make an audible clicking sound when you depress the key.
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8720
I'm a big fan of browns, blues are just a bit too loud for me.
3930k | RIVBE | 32GB Dominator Plat. | Titan XP | Intel 750 1.6TB | Mellanox 10Gb NIC | AX1200i
Custom TJ07 | 2xD5 pumps | EK Supremacy EVO | EK Titan XP | EK RIVBE Block | Cu Tubing | 25x120mm Rad
Samsung U28D590D 4K | Leopold Otaku w/Browns | Corsair M65 | Corsair SP2500 | Sennheiser HD595
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-8876
Browns or Blues, it all comes down to whether or not you want the loud clicky sound or not. If yes, get the blues, if not, get the browns. :)
I personally started with Reds, didn't like them at all! (There's just NO feedback at all with them) - so I swapped the keyboard for the same model but with Brown switches, and they're awesome (Like Blues but not as loud so I can still use my keyboard when everyone else in the house is asleep!) :)
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-9265
The main difference between browns and blue's are the sound, am I right? Cause in the middle of the night, I might see using the blue's a a problem :P And for the availability for browns, I can't seem to find any good-brand brown keyboards in Norway.
MEH
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-11146
I've been looking into mechanical keyboards a lot recently and made myself a quick chart about the different types of switches.
Still haven't decided which ones to get.
Specs: i7-3770K | Asus R9 290X | 32GB DDR3 | GA-Z77-UD5H | RM 750x | Define R5 Arctic White | macOS 10.14.5 & Windows 10
https://linustechtips.com/topic/397-choosing-between-mx-keys/#findComment-11335
