Problem with ASUS Xonar DGX 5.1
Solved by ShearMe,
Maybe your case doesn't have a good enough ground connection for all those components. Unscrew your PSU, scratch any paint off where the screws touch the case, then screw it back in. If the static lessens, but doesn't disappear, you know you're having grounding issues with your case. On my case (Silverstone FT03), There's no way for me to get a good ground without breaking out a welder.
