Hey all guys and girls!
I would like some new RAM, but I don't know what kit to choose. It should be a 2x8GB kit with some nice clock speeds and for reasonable price (I live in Czech Republic and here is electronics about 50 dollars more expensive than in America :( ). Im looking for something that is max 150 dollars. It will be used for gaming, video editing and lots of other stuff.
Thanks everyone in advance for your answers!
https://linustechtips.com/topic/39658-help-with-ram-please/
Pick the cheapest CL9 1600 ram you can find and you should be good.
Just run what motherboard you have by me just to be sure.
https://linustechtips.com/topic/39658-help-with-ram-please/#findComment-511644
http://www.amazon.com/Kingston-2133MHz-PC3-17000-KHX21C11T3K2-16X/dp/B00A772022/ref=sr_1_33?s=pc&ie=UTF8&qid=1374862208&sr=1-33
What do you think of this? Pretty good for the price. Aren't there some disadvantiges?
That RAM kit has CL11. Try looking for one with CL9, as WoodenMarker said.
Also, why do you need such high clock speeds?
https://linustechtips.com/topic/39658-help-with-ram-please/#findComment-513581
Umm, 8 GB CL9 1.5v dimm is hard to find cheap.... I have a 8GB 1333 Mhz Patriot Dimm wich luckily can OC to 1600MHZ@1.225v CL10. The thing is, if you can find a cheap 1333 memory, buy it! That's what I did!
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/39658-help-with-ram-please/#findComment-513927
AMD 8350 // 8 GB Corsair Ram // PNY 780 Ti // Asus 1080p Monitor // Antec 120mm AIO // CM Quickfire TK w/ Custom Caps  // RAT 5 mouse // Audio Technica m50x // Behringer 4-line + Line6 8-line Audio Interfaces
https://linustechtips.com/topic/39658-help-with-ram-please/#findComment-513994
Just get some cheap 1600 RAM. Ram is ram, doesn't really matter beyond that.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/39658-help-with-ram-please/#findComment-514004
