Hi! I installed asus al suit 3 and I am facing a problem with net icontrol! When i open it and click on auto to start tweaking things it says : Please connect to internet before using network i control . While i am sure my internet connection is fine and stable.
I tried to uninstall and reinstall and it didn't work! Any ideas?
https://linustechtips.com/topic/396542-problems-with-asus-network-icontrol/
Did you install all the other drivers?  What is the motherboard?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
