will 1tb hard drive and 120gb ssd be enough for games like dayz, reign of kings, ark, and stuff like that???
For the system OS and stuff on the 120GB drive yes but for games you would need to run them off the hard drive since you'd be pretty limited with the amount of space left at 120GB.
https://linustechtips.com/topic/396122-help/#findComment-5343645
ik but is a 1tb enough or do I need another?
Depends on the games and number of them you have but it should be enough, if you haven't bought the drive yet usually the 2-3 TB range offers some better value per GB without being too expensive overall.
https://linustechtips.com/topic/396122-help/#findComment-5343662
Well you should install your OS in the SSD, then put your games in the HDD.
So your SSD won't be filled too fast.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/396122-help/#findComment-5343694
