Is it a good idea to have a self-contained water-cooled graphics card besides an AIO CPU cooler?
Solved by Midnitewarrior4,
I'm pretty sure you cant plug the hybrid card into the 240 due to the gpu having its own aio it's not just a custom loop in its own. If you wanted to plug the gpu into the 240 then you need a card with a water block meant for a custom loop like the evga hydro copper or you would have to pickup a block from EK or someplace. Also you would not need a bigger res you would just have to add more coolant. Also you would want to add another radiator. Honestly it would be cheaper and easier just to run the evga hybrid on its own and leave the 240x just for your cpuI'll have to see if this particular EVGA model allows unplugging its own loop and can be connected to another. However, i'm not sure if simply connecting it to the H240-X would be enough, i suspect a higher quantity of coolant liquid would be needed (a new, larger reservoir) due to the longer, combined loop. This could be a plan for the future, but at the moment i kinda like the idea of having a graphics card that already comes with built-in watercooling, everything hassle-free and ready to roll.
