Yea... My 760 does this too, annoying as heck. I found that rolling back drivers and never updating drivers helps.
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5340647
My GPU does that sometimes when the driver crashes. Restart usually fixes this.
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5340722
could also bios flash and disable the low power state :D
New Desktop Project (currently work in process)
CPU: Intel Xeon E7-4890V2 @ 3,4GHz (1 of 4)
Mainboard: Supermicro X10QBI
Memory: 32GB DDR3 Reg.
GPU: AMD Radeon RX Vega 64 (2 of 4)
PSU: Corsair HX1200i
Case: Motherboardbox
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5340738
Remove your overclock, you drivers might be crashing and goes into safe mode (not an official term).
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5346931
My GPU will not boost at all it is always stuck at this even when at 100% load, restarting seems to sometimes fix it and other times it will be lower than this at 450MHz, or in rare cases it will sit at 1100ihs MHz at idle. Any idea how to fix this? attachicon.gifScreenshot (6).png
Had this with my 580 and 760; Restarting helped, i had to restart my pc like 5 times and after that it went away until it died :(. Reinstall Drivers etc. ofc.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5347111
GTX 480 did this when Kepler arrived... drivers bugged it all up.
AMD Phenom II B55 Quad / unlocked dual core 4.3ghz CB R15 = CB 422
XFX R9 390 8GB MY RIG: http://uk.pcpartpicker.com/p/MVwQsY
Fastest 7770 on LTT . 3rd Fastest Phenom II Quad on LTT
PCSX2 on AMD CPU? http://linustechtips.com/main/topic/412377-pcsx2-emulator-4096x2160-amd-phenom-ii/#entry5550588
https://linustechtips.com/topic/395885-gpu-stuck-at-540mhz/#findComment-5347798
