okay few weeks ago, my FPS did not go below 40 FPS (When driving).. But now i'm getting 30 FPS exactly 30 FPS...
Sometime it goes back to 50-60 FPS, and drops to 30 FPS.....
My Specs:
I3 4150
MSI R9 280X Core Clock (1140)
8 GB of RAM
Settings:
http://i.imgur.com/3YR76RN.jpg
http://i.imgur.com/8yTg5cV.jpg
http://i.imgur.com/cILg4cs.jpg
http://i.imgur.com/6UGD1KL.jpg
But keep in mind before i was getting a lot better FPS.
Seems like developers can't make a good game for PC..
I have a AMD Beta Driver (Thank god it's beta, so when it's fully released gta v might run better)
https://linustechtips.com/topic/394197-gta-v-fps-problem-please-help-me/
need more specifics, in city? in outskirts? in city you will get better FPS than the outskirts
Edit : you do NOT need Msaa 4x, for one even i am using Msaa 2x with a 78-oi
Edit 2 : Turn Post FX to Medium
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
I have the exact same graphics card, amount of ram and a slighty beefier cpu, and im getting the same issue. I think it may be drivers, as it happens on both the beta driver and old ones. I also get terrible artefacts... (not heat related, my gpu runs at 70c). I think we should just wait for optimisation.
My Specs:
I3 4150
8 GB of RAM
Settings:
Turn Vsync off, removes the FPS drop to 30fps, I know that you may have had this setting enabled days ago and had better performance with it on, but give it a try now.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
In city, when i get out of my apartment.
And yes i need MSAA at 4X, if it's 2X i get Graphics problems
http://i.imgur.com/CMnyoi0.jpg (Grass look at it!)
wait for what, we will be lucky if AMD fixes that, rockstar will for sure not.
Turn Vsync off :( :( :(
Screen tearing happens every minute.
Also removes the instant drop to 30fps.
Pretty sure though, with reduced settings you could keep your minimums above 45fps so it won't dip down to 30fps with Vsync on.
oh that's the problem turn off Vsync , your good to go.
PCPartPicker
No, i tried with settings on normal everything on normal i get 60 FPS and in few minutes (1-2) i get drop to 30 FPS.
Had GPU Monitoring in the background?
To check for limiting/throttling? - I dont think its the case, I think its more of a driver issue.
Works! Thanks but screen tearing is really bad.... I'm getting screen tearing quite a lot.
Why that Vsync bug be fixed soon? do you maybe know?
because you are playing at low settings/Res, hey atleast you can play now.
PCPartPicker
case isn't for sure i keep my case open like all the time..
I turned Vsync off and now it's good... But i get a lot but i mean A LOT screen tearing
really? so that will never be fixed?
I have some settings on High, and i can put texture quality on Very High and i lose only 2-3 FPS...
there's nothing to fix. you are playing and low settings and it suppose to be that way
PCPartPicker
WTF do you mean there is nothing to fix, few days ago i was playing on High almost everything on high 60 FPS and Vsync turned on... Everything was beautiful..
And now everything sucks!!
Rockstar need to fix few things, and High to you means low lol
if it was working 2 days ago and not working now, then its not rockstar's fault, because they didn't do nothing to your game. you should find something else to blame.
PCPartPicker
idk, i just know 2 days ago everything was good. Now, everything sucks.
Maybe i need to reinstall Driver (It's beta)
Just in case of swapped driver corruption, use DDU (DisplayDriverUninstaller) - It removes the junk traces left behind between driver installs.
Adaptive v-sync will run a game at either 30 or 60fps on 60hz panels
i7 6700K - ASUS Maximus VIII Ranger - Corsair H110i GT CPU Cooler - EVGA GTX 980 Ti ACX2.0+ SC+ - 16GB Corsair Vengeance LPX 3000MHz - Samsung 850 EVO 500GB - AX760i - Corsair 450D - XB270HU G-Sync Monitor
i7 3770K - H110 Corsair CPU Cooler - ASUS P8Z77 V-PRO - GTX 980 Reference - 16GB HyperX Beast 1600MHz - Intel 240GB SSD - HX750i - Corsair 750D - XB270HU G-Sync Monitor
