Can I tape the box with electrical tape?
Why not just get a roll of clear packing tape or duct tape.
For the item just be sure to wrap it on bubble wrap and anti-static bag ideally.
Edited by W-L
https://linustechtips.com/topic/394165-rma-packaging-help/#findComment-5318787
they suggest reccomend not to use duct tape for some reason
If it's the box and not the item itself I don't see why it would be a problem as long as it doesn't cover important UPC labels/bar codes.
https://linustechtips.com/topic/394165-rma-packaging-help/#findComment-5318826
