Overclocking a Godavari Build
Solved by arnavvr,
Hey Guys, I am a noob to overclocking as well as LinusTechTipsForum.
I created an entry level system. It works great for my audio mixdown's and my daughters games. Here are some of the specs:
AMD A10-7870K 3.9GHz Quad-Core Processor
ASRock FM2A88X+ BTC ATX FM2+ Motherboard
G.Skill Ripjaws X Series 4GB DDR3-1333 Memory
Corsair 430W 80+ Bronze Certified ATX Power Supply
I want to overclock the APU to about 4.5GHz and overclock the memory to about 1866.
My question is, what type of cooling would I need to have the system run at an optimal temperature (water cooling or air cooling), & what testing software do you recommend?
Hyper 212 Evo. APU's don't get that hot.
