That computer is so old there is no point...
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312727
Normally I'd say get a new PSU and a lower-end 700-series card (or a 260x), but wow. that's old.
I thin you'll want to build a new PC overall, since there are going to be bottlenecks everywhere
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312728
hmm R7370 i guess.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312730
I having an old system:
cpu: intel pentium e6500 2.93 ghz
ram: 4gb of ram
psu: standard atx ps2 power supply 400W
graphics card: gigabyte gv-nx84s512hp 512mb
And i need to upgrade my graphics cards, so which should i use?
Thank you
Best thing to do. Is actually upgrade your hole system. Save money. around 500$ and you get a new pc.
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312736
R9 270, getting anything better makes no sense because the PC is old. But tthis will give a nice boost, overclock your CPU and you will be able to play most games on decent settings.
Specs: AMD FX 6300 @ 4ghz, Asus R9 270 OC, 8gb Corsair xms3, Cooler Master GX 550w PSU, WD 500 blue, Gigabyte  GA-970A-DS3
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312739
ram: 4gb of ram
Thank you
I think that PC would use AGP and AGP GPU's are not made anymore so just get a new PC
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312752
possible, that socket is from the same year as PCI E 1.0 ...and its likely a prebuilt where they went cheap.
edit nah thats a PCI-E card, but I stand by my statement of dont bother and just get a new comp.
System Specs
https://linustechtips.com/topic/393700-help-me-please/#findComment-5312767
