Is this power supply sufficient?
Go to solution Solved by AlwaysFSX,
Why on Earth would you get a 4690k and a bloody H81 board?!
So I'm planning to replace my old computer with one I'm going to use for many years.
This is a Link to my build -  http://ca.pcpartpicker.com/p/pDqNHx
Would you recommend a Corsair cx500W or should I go for the Corsair cx600w? I believe it would be enough to power my system to boot but is there anything I should be considering? Such as a depreciation on the power supply if used for many years. I don't plan to overclock or SLI/crossfire my computer.
https://linustechtips.com/topic/393601-is-this-power-supply-sufficient/
For $80 you can get an EVGA Supernova GS. Corsair CX series PSU's are not good imo. Also, you will need a Z97 board to overclock.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
I would only understand a H81 board for the G3258... go for a z97 and yes your PSU is efficient enough.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
OP doesn't want to overclock.
Cheapness level has gone off the roof.
I swear some people need to put in those five seconds of thought to understand what they're doing.
i wouldnt recommend Corsair's CX series. i would suggest getting seasonic s12II almost the same price but it performs much better
Current Gaming Rig Specs
   CPU:    Intel Core i5 4460  --   GPU:   Zotac GTX 980 Ti Reference Card --   RAM:   G.Skill RipjawsX 8GB 1600 --  Mobo: Gigabyte H97M-D3H --  HDD:  1TB Western Digital Caviar Blue
PSU: Seasonic S12II 620w 80 Plus Bronze -- Case: Bitfenix Shadow --  Monitor: Benq RL2455HM 24"  -- Mouse/Keyboard: CMStorm Devastator
Order everything from memory expresses, they will price match any competitor and save you 10% on most of the things that are cheaper elsewhere.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($284.98 @ DirectCanada)
CPU Cooler: be quiet! PURE ROCK 87.0 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($132.99 @ NCIX)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Memory Express)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive ($67.99 @ Canada Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($60.75 @ Vuugo)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($429.99 @ NCIX)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($59.99 @ Memory Express)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.98 @ Newegg Canada)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($109.99 @ NCIX)
Total: $1326.64
Generated by PCPartPicker 2015-06-25 03:33 EDT-0400
EVGA GS series is also around the same cost and is so much better then the CX series.
Can you tell me the reason why a H81 board is considered a bad idea for a 4690k?
Edit
- Oh crap its because 4690k is more for overclocking isn't it, whoops my bad, guess I'll get a 4460 instead.
Thank you guys for pointing out my mistake.
$80 for a CX500 is ridiculouses
http://ca.pcpartpicker.com/part/evga-power-supply-220gs0550v1
"Rawr XD"
