Hi,i am going to upgrade my GPU to a GTX960/285 or something along that line but i currently have a corsair VS 650 power supply will that be a problem(big problem)
my processor is the FX6300.And do i have to change this PSU if i want to overclock the CPU and GPU a little bit.
https://linustechtips.com/topic/393214-will-it-be-enoughthe-vs650/
not even a little bit,i can enable turbo core with out any problem right and what will happen something happen will my whole pc get damaged?
You can overclock it, but dont OC it too much.
"an obvious supporter of privacy"
That should be fine. The GPU is going to be using about 280watts (under load) and your other components processor, motherboard, ram etc shouldnt use more that about 300watts (under load) so a 650watt PSU will handle that kind of power draw, no problem.
Ya but many say since it is a 'VS'(the lowest version of corsair PSU) and it doesn't have gold plus rating it will be having problems when i overclock,i guess it will be fine but if anything goes wrong will my whole pc get damaged or just the PSU or both.thank you for the info.
