I use shadowplay a lot. Just to record cool moments.
Why not use FRAPS? I also had problems with GFE, uninstalled and poof, problems gone... The "optimization" for games is useless, as it picks overkill settings most of the time, and other than the Shadowplay feature it is kinda... not needed, at least for me
I don't record for youtube or anything. I like shadowplay because I can just get a cool moment if something happens. I don't like to record all the time.
Have you tried installing just GFE? I mean get a separate installer just for GFE, not the whole driver... it fixed an issue I had previously
Update drivers of the game and of the geforce expierience
I think its somekind of Driver connection propblem
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
What driver version are you on? I've reverted back to the GTA release (the two later ones crash when chromes open at least twice a day). Then I wiped all drivers with DDU and reinstalled GTA 350.12 without GFE. No problems since, but since you use Shadowplay that's not an option I guess. GFE has been extremely buggy recently, so I'm in the same boat as Scotty. It's probably an issue on NVIDIA's end, so maybe rolling back to GTA and installing GFE from that driver may work again (use DDU beforehand, not clean install from drivers).
I may or may not be crazy...
My Build: GA Z77X-UD5H (f14) • i7-3770K @ 4.3GHz • 16GB 1600 MHz Corsair Vengeance (Using XMP) • EVGA GeForce GTX 970 SC • 120GB Kingston SSD for OS X Yosemite 10.10.2 • 250GB 840 EVO for Windows 8.1 • 1TB Seagate Barracuda
• 2x1TB WD Caviar Black RAID 0
Will try thank you.
