Best mouse for small-medium hand?
Go to solution Solved by ZetZet,
G303.
It's quite a different grip, but look at the Zowie ec1-a.
or ec2-a or za13
G303.
or ec2-a or za13
What is the best (most comfortable) mouse for small to medium hands? One that doesn't strain the hand when gaming for long periods in one sitting. Any grip type is fine, as long as it's comfortable. I liked the feel of the g502, but it was a bit too big for me.
was gonna say g502 lol.
check out the g402 and g303
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
 I have the G303 and I was gonna return it because my hand started to strain after 3 hours (with breaks) of playing.
My hand also got tired when I reduced sens for cs. But I kept it up and now it's perfect.  :lol:  Maybe it just doesn't fit your grip, it's more of a claw mouse.
Yeah probably. I can adapt to any grip, but I my palm starts to hurt when I use my "preferred" grip, which is fingertip.
Is the SteelSeries Kana v2 any good?
I would look into Zowie mice for that shape instead.
