Can't open Origin, help.
Go to solution Solved by Patachaos,
I finally fixed this.
I deleted some files from regedit.
And then i tried again.
Then a message with a link apear
https://download.dm.origin.com/origin/live/OriginSetup.exe
I download it.
It installed.
And it finally worked.
Thank you all for your help.
And thank you to techguru for being like +2 hours on team viewer with me tryng to change the OS lenguage.
When i try to open origin this error message appears.
Translation:Windows can't find the file C:Program Files (x86)\Origin\Origin.exe Check the name if is correctly typed and try again.
The file is there. I checked on google but i didn't find the answer.
Then i tried changing the name of the file and it worked. Origin was oppened but i couldn't do anything because a error poped over and over. A similar error but with the OriginCliendService.Exe File.
I don't know what to do now.
https://linustechtips.com/topic/391297-cant-open-origin-help/
Looks like there's a bit of the install missing there..
Try running as an admin or reinstalling Origin?
I runned the instalaccion and the Origin.exe as admin and still the same error.
turn on file extensions to
sounds like a permissions issue
check your permissions on the folder
How do i do that?
https://linustechtips.com/topic/391297-cant-open-origin-help/#findComment-5282073
I download it.
It installed.
https://linustechtips.com/topic/391297-cant-open-origin-help/#findComment-5283624
