Hey everyone. So today i looked at my CPUID and took a stroll down my temps and seen my GPU is running hot. I just did a full rebuild on my computer yesterday (new case, h100i for CPU). I am 90% sure i shouldn't be idling at such a high temp. Anyone know anything that might help here or why its so hot. Fan config is two 140 intake in the front, one 140 exhaust in the rear, two pushing out the top of case ( h100i). Case is a Graphite 760T.
https://linustechtips.com/topic/391230-980-ti-running-hot/
is the fan running loud as a tubine engine?
you might want to try and reapply thermal paste
and what cooler does it have? reference?
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281147
Video card shouldn't need to have thermal paste reapplied
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281155
idle at 78c is a problem
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281185
Check clock speeds in MSI Afterburner, probably not downclocking. A lot of Maxwell cards have that problem.
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281194
60°C is not as hot as it sounds, my card tends to idle around that temperature since the fans don't spin, so it is basically passively cooling using the heat-sink. it only rises by 10°C to about 70 at full load. What are your load temps like?
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281201
Its brand new but theres a chance they f*cked up when the machine attached your thermal-paste.
I would either replace that and hope that would fix it or turn the fan up.
If nothing helps you i don't see why they wont swap it for you.
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281203
That's..... odd. Mine idles around 27-30.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5281317
I believe I solved mine. I replaced the thermal paste. It seems to have stopped throttling now and I scored a 4100 on 3d mark ultra 4k. Compared to benchmarks from other sources that scored around 3900-4000, I would say mine is now operating properly.
ASUS Z77 Sabertooth
Intel i7-3770k 3.6Ghz
Nvidia 660ti
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5340111
If you got a reference cooler 980ti I'm sorry... That's what a reference cooler do when you put an old design on a new power hungry graphics card. Not much you can do but improve case airflow
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5340140
I'm running triple 1080p on my 980 Ti, and it idles at around 32c but if I'm watching a stream it idles at 42c, it might just be an issue with how the TIM was applied at the factory. My 980 Ti is the gigabyte ref one as well. Also while I'm playing BF4 it never goes above 75c with +200 on the core and +350 on the memory, thats also running the game at max settings with 150% resolution scale.
i5-4670k 4.5 Ghz 1.25v | Gigabyte Z87X-UD3H | 4x4 Gigs of Corsair Vengeance Pro 1600Mhz | Gigabyte 980 Ti Reference 1503 Core/ 7796 Effective Memory | H100i w/stock fans | EVGA Supernova 1000w G1 | Samsung 840 120Gb SSD | Seagate Barracuda 2TB 7200RPM | Corsair Force LX 128Gb SSD | Fractal Design Arc Midi R2 | DT 990 Pro 250Ohm | Blue Snowball | Logitech G710+ | Logitech G600 | Acer H236HL BID x 3
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5340141
EVGA tech support says because i am running 1080p 144hz and 1080p 60hz monitors on the card it is stressing it and making it idle at 60c.
My Titan X idles at 45c when and I am using 1440p 144Hz so that makes sense. It was running at 68c during idle. I set a custom fan profile and that got it down to 45c. I advise you do that. I use EVGA Precision X 16 or you could use MSI afterburner.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5341042
You realize the new design is actually more energy efficient and shall we say "greener", right?....
ASUS Z77 Sabertooth
Nvidia 660ti
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5341475
Not using NVidia but that shouldnt stress the cards to run idle 60°C wtf. Im idling at 47°C, however my room temp is 30°C right now xD.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/391230-980-ti-running-hot/#findComment-5342588
  • 4 weeks later...
