Im having a problem with my graphics card and this problem has only occured over the past few days.
When i boot up my pc the graphics card's fan boots up with the card and starts to spin but nothing is displayed to the monitor.
I have had to repeatedly had to turn my machine of and and on again so the gfx card would boot, but when i went to turn it on today it will not boot at all.
I think it may be dead but im not sure.
https://linustechtips.com/topic/39101-graphics-card-issue/
I'm not sure I understand your problem, your graphics card spins up but doesn't display anything? What GPU is it? How long have you been using it? Was it working before? Have you tried with another monitor to make sure that's not the problem?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/39101-graphics-card-issue/#findComment-503392
First off, try removing the card and then re-install it.  Might not be seated correctly.  It could also be an issue with integrated graphics if you have it.  If so, try booting with the card removed and the monitor plugged in through the mobo.
Use another monitor or test to make sure your current one is completely working.
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
https://linustechtips.com/topic/39101-graphics-card-issue/#findComment-503440
I have removed the card and re-installed it, and the on board graphics are working as that is what im running off of currently. It's when i boot my machine up the gfx card's fan spins up like its working but wont display anything to my monitor.
First, what is your PSU. What graphics card is it, how are you connecting it to the monitor?
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/39101-graphics-card-issue/#findComment-504056
