Hey guys, I am going to build my first NAS. It's going to be used to backup our 4 computers, stream HD content to our HTPC, and store pictures, videos, and music. I am planning on running RAID 1, and using FreeNAS. Tell me what you think.
http://pcpartpicker.com/p/1kbdq
https://linustechtips.com/topic/39082-help-with-nas/
WD Greens are bad for use in a NAS, using something like a WD Red or Seagate Barracuda.
https://linustechtips.com/topic/39082-help-with-nas/#findComment-503112
In my understanding he should be perfectly fine with WD Greens. The Speed is normally limited by the internet connection (and even if not, a bakcup doesn't have to be as fast as it gets) and with 2 Drives there shouldn't be any problems with vibrations and stuff.
  • Primary PC: i7-3770K@4,6GHz | Thermalright Macho | ASRock Z77 Extreme 4 | 16 GB Corsair Vengeance@1866MHz | 2x Gigabyte 660ti 3GB@1130MHz | 256 GB Samsung 840 | WD Black 1TB | BeQuiet! DarkPower Pro 650W | Zalman Z11
  • Secondary PC: i7-860@3,1GHz | Scythe Katana 3 | ASUS Maximus III Formula P55 | 8GB Corsair Vengeance 1600MHz | 2x Zotac GTX 280@650MHz | WD Velociraptor 500GB | Seagate Barracuda 2TB | BeQuiet! DarkPower Pro 750W | Coolermaster Cosmos S
https://linustechtips.com/topic/39082-help-with-nas/#findComment-503189
Greens aren't made to withstand the vibrations of other drives near by.
hello
https://linustechtips.com/topic/39082-help-with-nas/#findComment-503247
With 2 drives in an MATX case? Dude there shouldn't be any vibration issues. You couldn't use greens in any scenario if they couldn't withstand this.
https://linustechtips.com/topic/39082-help-with-nas/#findComment-503258
No problem man :). I thought about posting the same for a few secs until I saw the case :). By the way that's the only thing i would change. Get a M-ITX amd mobo and a smaller case. In my opinion a matx case is way to large for a 2-drive NAS.
https://linustechtips.com/topic/39082-help-with-nas/#findComment-503275
