Hey,
I'm going to do vacation work, and planning to save up for a computer.
So far this is the parts im planning to buy and need advice what I should change and everything will work correctly.
CPU: 4670k
CPU cooler: H100i
Motherboard: MSI Z87-GD65 Gaming
GPU: GTX 770  4gb gaming
Harddrive: 1 TB WD black
Memory: Corsair Vengeance CMZ16GX3M2A1600C9 2x 8gb
PSU: XFX PRO850w
CASE: NZXT PHANTOM 820 (allready bought)
SSD: Allready bough
Sorry the URL's are forwarding to dutch website, That's just because I use their pricewatch and It will auto link when i copied the name.
Prices includings delivery costs, I live in the netherlands so just give me advice what I should change instead of NCIX or newegg links for cheaper products.
My budget will be arround 1300-1400 euro if you click the link you will see the actual prices.
If my budget will handle it I will also purchase extra fans with it.
Looking for a dutch gaming clan? http://fapp-crew.nl/
https://linustechtips.com/topic/39072-need-advice-for-this-build/
Hey,
Proccesor: Intel Core i7 3770K Boxed - € 285,90
CPU cooling: Noctua NH-D14 - € 164,-
Motherboard: MSI Big Bang MPower Z77 - € 365,50
Videocard: Gigabyte GV-N770OC-2GD (GTX 770) - € 231,30
Case: NZXT Phantom 820 - € 67,90
Ram: Corsair Vengeance LP CML16GX3M2A1600C9 - € 132,-
PSU: Corsair Enthusiast TX750M (Not 100% sure about this one though) - € 102,70
What are you going to be doing with this build? If you're just gaming, you could step down the CPU a bit to save money and spend it elsewhere. Also, how much RAM are you getting?
Feel free to message me if you want to chat!
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503014
16 gb edited the post, Also yes I will be heavily gaming but choose the i7 just incase it would be helpful in couple months/years ?
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503033
If you're just gaming, step the RAM down to 8Gigs. Also the i7 will be useful if you're video editing but not just 'in a couple of years'. Maybe if gaming leverage hyperthreading more. Also, you need to get hard drives and an OS included in the budget. I reccomend a samsung 840 SSD they're cheap and reliable and fast. You could also grab an HDD for other data.
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503040
Sorry forgot about that, I allready have an SSD I'm just planning to transfer it to the new computer once it's build and yes completly forgot about adding an HHD to the list, It got somehow removed from my wishlist so I forgot about it.
But I will just grab a good one based on the pricing and rating at the time im going to buy everything.
Ok I would consider buying an i5 instead of an i7 as it would also save me 100 euros.
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503080
It could do :P Then throw it at a better GPU
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503089
What I have seen the GTX 770 performs really well and it doesn't cost a lot of money, But what would you recommend?
There's still upgrades to be had. 780 and what have you. You could also step down the cost of the case too and be on a headstart to SLI 770s or something?
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503102
there is a possibility of fitting 780 in this build, but i rather get 770 and PSU that will handle SLI later
Will the TX750M able to run 770 SLI fine? Or do you have any better suggestions?
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-503659
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-505558
2 760's in SLI scale very well, and will cost lest than a 780. they will surely handle virtually anything in 1080, though you have not mentioned your monitor/resolution setup.
and im always bias towards budget side of things, so 8350 ftw :D
Rig
CPU: 4770k @ 4.2GHz 1.15v | Mobo: ASUS z87 Sabertooth | Cooler: Corsair H110 | RAM: Vengeance 32GB DDR3 @ 1600MHz | GPU: GIGABYTE G1 GTX 1070 | Storage: Samsung 840 series 250GB SSD, Seagate 2TB SSHD, Seagate 4.25TB HDD | PSU: Corsair AX850 80+ gold modu | Case: Corsair 650d | Keyboard: Corsair K65 RGB Cherry MX Reds & a Leopold 210TP Numberpad Cherry MX Blues | Mouse: Logitech G502, DECHANIC desk mat | Monitor: 2x Dell IPS 23" S2340m & ASUS 144hz 24" VG248QE | Speakers: CA-3602a | Headset: Steelseries Syberia v2 Frost Blue OS: Win 10 Pro
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-505904
I need more opinions on this one, Should I go with the 4th generation or just purchase the third generation?
I know Haswell has about 10% better perfomance but also heard they tend to run very hot.
So what should I do 3th or 4th generation, Please state why.
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-518204
3rd gen i5, you are gaming then the hyper threading on the i7 won't help unless you are video editing/rendering and the like. also, if you think overheating is a problem, you have a noctua fan, if the case you chose has good airflow, you should be fine (especially if you can pick up some Noctua case fans, you will definitely be in the clear :P )
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-518632
Haswell runs almost just as hot as Ivy but they variate a bit more than Ivy on the overclocks.
It's still plain 10% faster than Ivy so you should get it unless it was significantly more expensive.
There's really nothing Ivy has over Haswell except being slightly cheaper.
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-518736
Allright I might get the 4th generation then, But I see you put the Gigabyte GA-Z87X-D3H in the list of updated parts but I also like the MSI Z87-G45 Gaming motherboard and that one will look neat in my case.
Which one do you recommend or are the difference minium that it doesn't really that matter that much?
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-518876
Both mobos work just fine and will do everything you need.
Can't go wrong with either.
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-518916
  • 2 weeks later...
Because I would get more money then i thought I have changed some parts.
So far this will be my build:
CPU: 4670k
CPU cooler: H100i
PSU: XFX PRO850w
If my budget fits I will also get the CM storm quickfire rapid black.
If somebody has tips improvements etc, Please tell me. Also the keyboard can change if you have beter suggestions!
https://linustechtips.com/topic/39072-need-advice-for-this-build/#findComment-577183
