Is there such thing as a PCI bracket where you can mount 2 fans? sort of like this:
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/389876-pci-bracket-for-fan-mounting/
Insert   Dank   Signature   Here.
lmao thats awesome. You think its worth buying these things?
Like?
Cooling VRMs from a DIY water cooled GPU
Cooling VRMs from intense overclockers that need extra cooling
You think this is worth it for lowering GPU fan speeds?
Not sure, @Faceman may know more than me as he told me about them.
Doubtful.  I only recommend these PCI fan brackets for the G10 mod when there is no airflow over the VRMs.  I think the distance, and the blockage of the stock cooler is too much to overcome, plus these things aren't exactl quiet themselves.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
Well i was thinking mounting some after market fans, Like Noctuas, as "replacement" fans for the GPU fans.
Its still not going to be enough to overcome the blockage that is the stock cooler.  The stock cooler is designed very well, even though it is loud.  The fans are blowing directly over the heatsink, which cools the core, and behind the heatsink is the VRM circuitry, which also gets pretty direct airflow from these fans.  Spending ~$30-40 on this is not a good use of money in my opinion.
