Hey guys, I am looking for the best possible settings for streaming FPS games. I understand a good bitrate is around 2500 but I don't know anything beyond that and could really use a hand. If you guys have any links or screenshots to settings I could use that would be great :).
https://linustechtips.com/topic/389415-obs-settings/
AlwaysFSX has a thread on OBS you might be interested in reading! Might help you get in the right direction and if not, maybe AlwaysFSX can help. :)
http://linustechtips.com/main/topic/358175-how-to-why-quicksync-and-open-broadcaster-software-picture-heavy/
https://linustechtips.com/topic/389415-obs-settings/#findComment-5257497
stream settings, all I've been told is to set the bitrate to around 2000-2500 for Twitch.
what is your upload speed?
https://linustechtips.com/topic/389415-obs-settings/#findComment-5257516
My upload is around 15
then your bitrate should be a little less than half? i remember someone telling me that your streaming bitrate should be upload/2 - some
but then again i cant be sure as ive never streamed
https://linustechtips.com/topic/389415-obs-settings/#findComment-5257534
What's your internet speed's and computer specs?
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/389415-obs-settings/#findComment-5257540
Bitrate should be 2000-3500 depending on quality and resolution. Having 7500 bitrate is useless as only Twitch partners have ability to scale resolution to viewers. In other words, having over 3500 bitrate, your viewers would need to have as good internet as you do. Most don't. So you gain more viewers by dropping quality a bit, like to 2200-2800 for 720p stream.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/389415-obs-settings/#findComment-5258433
