So I was wondering if it's just a driver issue or I simply can't overclock any further or not.
I can't get past 1565MHz on core or the driver would crash. GPU-z says I'm no where near the power limit (it hovers around 70% and below half the time), doesn't look like it's using a lot of voltage either.
Did I just reach my GPU OC limit?
Mid-range Emulation Gaming and Video Rendering PC
[CPU] i7 4790k 4.7GHz & 1.233v Delidded w/ CLU & vice method [Cooling] Corsair H100i [Mobo] Asus Z97-A [GPU] MSI GTX 1070 SeaHawk X[RAM] G.Skill TridentX 2400 9-11-11-30 CR1 [PSU] Corsair 750M
https://linustechtips.com/topic/387608-gtx-970-oc-help/
1565Mhz is quite abit?
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231036
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231040
I was hoping to reach 1600MHz lol.
Anyways, I just wanted to check since I heard about the latest drivers causing issues with overclocks.
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231048
You do know people hitting 1600MHz+ on the core are just doing it for benching purposes and 90% of the time not stable at all right?
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231081
Ah, I didn't know that.
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231105
1600Mhz is not impossible but uncommon I have mine on water but can only get that when benchmarking almost never goes that high during games.
https://linustechtips.com/topic/387608-gtx-970-oc-help/#findComment-5231158
