might as well get a snow white case with that snow white motherboard
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/386845-thoughts-on-build/#findComment-5220730
stupidly overkill motherboard and RAM...find cheaper ones and dump more money on a GTX 980 instead.
Also, i don't thing the AIO you picked would fit in that case...and thermaltake is crap.
This IMHO would be much better...
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ NCIX US)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($89.99 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($115.99 @ SuperBiiz)
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1866 Memory ($93.99 @ Newegg)
Storage: Crucial M500 960GB 2.5" Solid State Drive ($306.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card ($499.99 @ NCIX US)
Case: Corsair 760T White ATX Full Tower Case ($147.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($104.99 @ Newegg)
Total: $1589.91
Generated by PCPartPicker 2015-06-14 20:43 EDT-0400
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/386845-thoughts-on-build/#findComment-5220741
i would also recommend maybe instead of spending so much on the ssd and get a 1tb hardrive and 256gb ssd and get a 980 instead
https://linustechtips.com/topic/386845-thoughts-on-build/#findComment-5220744
http://pcpartpicker.com/p/rFrGzySame thing for the price.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/386845-thoughts-on-build/#findComment-5220752
https://linustechtips.com/topic/386845-thoughts-on-build/#findComment-5220768
