Main System                                                             Accessories
Mother Board: Rmpage V Extrme                               Monitor: Acer Predator XB270HU
Storage: Intel 750 Series Nvme 1.2tb                           KeyBoard: Corsair Gaming K70 RGB
Cpu: I7 5930K                                                             Mouse: Kone Tyon
GPU: 2WaySLI GTX 980Ti                                           Headsets: Steel Series H Wireless
Ram: G.SKILL Ripjaws 4 series 16GB
Power Suply: Seasonic 1050 watt
Case Hardware
Phanteks Enthoo Primo SE Orange                            UV Leds: DarkSide 12
8*NF-F12 industrial ppc 3000rpm pwm                        5*PrimoChill Fluid Dye - UV Electric Blue
Delta "Mega Fast" 120 - 252 CFM                              5*EC6 Coolant Clear UV
1*NF-A14 industrialPPC 300 rpm pwm                        UV Leds: Phobya UV LED Strips
Water Cooling Hardware
Radiator: 2*Alphacool NexXxoS ST30 Full Copper 480mm
Pump: Alphacool VPP655 PWM 1/4
Reservoir: Photon 270
Cpu Block: RayStorm CPU WaterBlock (Intel) Copper
Gpu Block2*Razor GTX Titan / 780 / 780Ti V2
Fittings& Hose
M20 to G1/4″ Fillport
G1/4″ 10mm Male to Male Fitting
Hose: HighFlex Hose 19/12.7mm, 2m, Clear/UV
https://linustechtips.com/topic/386836-updated-build/
Woah.. Can.. Can I get a picture :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/386836-updated-build/#findComment-5220689
Gaming, working , cad, inventor, cinema 4D , recording, overclocking, looks. so i can get a boner whenever I look at it xD
5820k dont bother with the 5930k for 200mhz difference
Assuming you actually buy that thing anyway
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/386836-updated-build/#findComment-5227449
