Intake or outtake fan
Solved by Homicidium,
To be perfectly honest, dude. The best thing is to buy a while new case with space for more fans. You don't need anything fancy.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075
This offers enough space for your components, has even some light cable managment options and space for up to 3 Fans. Simply buy some cheap fans like from Cooler Master or NZXT and you have no problems with heat at all
