Can i use either of these power cables on this power supply?
Luke
So i'm just going with the safe bet and not using these cables because a normal one says "10A - 125V" but i have one that says "13A - 125V" and another that says "10A - 250V"
Anyone know for sure? Help would be much appreciated. Thanks.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
They're all good as long as they aren't missing pins or damaged. the higher amperage one is good for if your system draws a shit ton of power, basically equating to thicker wires in the cord.
eeeehhhmmm should be good, I swap my cables all the time (by accident when moving) xD
Hardware: 4790k @ 4.6 GHz w/ H100i - MSI GTX 970 - Define R5 - MSI Z97 PC Mate - 840 EVO - G.Skill 2x4 GB
Peripherals: G402 - ATH-AD700x - Asus VG248QE 144 hz
The cables are simply rated to handle those voltages and amps.
Thanks for the help!
As long as it fits and it's rated higher then stock, you're fine, if not better.
"Rawr XD"
