I dunno, if you have a speaking car ask the car what it wants.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/386289-car-speaks/#findComment-5214185
Did you get a model with the JBL speaker system, or without? Either way, Crutchfield.com is saying you need 6 and a half inch speakers for both front and rear. I recommend shopping there for the installation parts you'll need, if not the entire upgrade.
I had some Infinity speakers installed in my Yaris that had great mids and highs. Swapped them out for something different and ended up regretting it in the long run
https://linustechtips.com/topic/386289-car-speaks/#findComment-5214518
wow how did I mess up the title like that.
Thanks, I'll take a look at them.
https://linustechtips.com/topic/386289-car-speaks/#findComment-5216800
