Hi, i would be more than delighted if anyone can solve my problem. AS I POSTED ON MANY THREADS AND I GET NO REPLIES. ):
So firstly i don't know why my frames rate drops from 83 to 40+30 dramatically I'm not even playing a high end game.. the game's GPU only requires GeFORCE 7600 GT..? i'll provide a link for that.
http://www.game-debate.com/games/index.php?g_id=3354&game=Sudden%20Attack
So i'm using a laptop. LENOVO y500, the specs are definitely way better than the requirement.
SPECS:
i7-3630QM
16gm ram
750m sli(but i didn't on the sli)
i previously used before a low end laptop with  Nvidia 920m and it lags lesser and i have a 330m nvidia laptop with me it dont even lag much expect that the laptop itself is quite spoilt..
however i tried playing it on a ROG. idk which model but uses gtx860 it has the same issue as my current one...? somebody PLEASE?!
https://linustechtips.com/topic/385769-help-pleaselag/
My first question is does it only happen with this game?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5207887
Not really.. I play a little of TERA as well and the FPS doesn't really mark up to my lappy specs. it does lag a little as well but not as smooth as it should be.
Did you do a clean install of Windows or are you still using the OEM install?
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5208190
I bought it from a big retailer (i'm from singapore) so no way it's an oem.
So you did a clean install of the OS?  Then that makes me wonder if you installed all the drivers, or just the ones you felt like installing?  (Its okay, we've all done it)
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5208451
I'm quite a newbie so do tell me if i had not download any.
i downloaded my gpu driver as well as directx11 that's all.
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5208518
Have you run Windows update? Important updates missing has caused sporadic poor performance for me before
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5208659
Yep, you probably got at least a dozen more to download and install.
Check that out, if you still have questions (or you would like me to actually help) send me a message.
https://linustechtips.com/topic/385769-help-pleaselag/#findComment-5208836
