So I need silent fans or near silent that are not really expensive aka Nactua. I need 2 or 3 for a Bitfenix Prodigy. It is my server and it is in my room so I want it to be near silent for when I sleep being it will be on all the time.
My rigs
Desktop CPU: Intel Xeon E5-1680 v2 @ 4.4GHz cooled by a Corsair H105 | Motherboard: Asus Sabertooth X79 | RAM: 32GB G.Skill Sniper DDR3 1600 | GPU: EVGA RTX 3080 SC3 Ultra Gaming | SSD: Samsung 860 EVO 1TB + Crutial M500 240GB + Samsung 840 120GB | HDD: Seagate Barracuda 2TB 7200RPM + WB Black 4TB 7200RPM | Case: Fractal Design Meshify C | Mouse: Logitech G402 & MX Master | Keyboard: Poker II  MX Blue & Leopold 10-key pad Box Royals | Monitor: LG 34UB88-P | Audio: Audio-Technica ATH-M50 + FiiO E5 DAC + Rode NT-USB Mini
Laptop Lenovo Yoga 720 4k Touch
https://linustechtips.com/topic/38529-quiet-case-fans/
Noctuas are the most silent. If not Corsair has a few silent optimized and good looking fans
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495506
Yeah I know nactuas are but they are just too much for me. So are you talking about the SP-120 air series?
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495513
just adjust the speed to around 800rpm from my experience that is nearly silent
I have done that but I have really bad fans and still are still loud.
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495518
Be Quiet! silent wings 2 are good fans, but pricey.
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495525
I got some Cougar Turbines and once its undervolted its not not that loud imo. Connected one to a motherboard header to adjust the speeds.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495531
Like more than Nactua?
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495549
I have Silverstone AP122 as my case fan and you can't hear it when it's on 7v.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495614
They are pretty close it's in that top tier of fans from vendors like Noctua, noiseblocker, and phanteks. I prefer Be Quiet! fans because they look so much better and are extremely quiet. Linus has a video about there 120mm fan.
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495627
If for rads, yes. for case fans go for the AFs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495821
The only problem with the AFs is if you have anything that could obstruct it's airflow it has no real static pressure to overcome that.
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-495858
You're Wrong. Theyre P-12 is Extremly silent if you compare it to their new fans (A-14,F-12,A-15). There are quieter Fans out there.
Prolimatech Red/Blue Vortex 14 for 140mm i have them and they are UNHEARABLE at 12V. and i rly mean Unhearable if you want i do a Video. It's Quieter than my Noctua NF-F12 with it's L.N.A Adapter. for 120mm Bitfenix Spectre Pro or Cougar Dual-X
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-496149
There is nothing in the way, the drives are right below the mounting point so it is a straight shot to the important stuff.
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-497911
One problem, it is about $30 for 1 fan http://www.newegg.com/Product/Product.aspx?Item=N82E16835242015 if I got the wrong fan then let me know.
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-497935
Just for everyone's info, I have a fan controller. I think I forgot to mention that earlier.
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-497944
How am I wrong when I said Noctuas are one of the most slient ones?
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-497978
Wrong Fan i did mean those : http://www.prolimatech.com/en/products/detail.asp?id=161&page=1
http://www.prolimatech.com/en/products/detail.asp?id=1076&page=1
but only the 140mm one is quiet the 120mm is loud ;) i own the 140mm and srsly they are quiet and looking good.
Sry ive read  "Noctuas are the most silent ones" i'm sorry.
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-498279
Ok I figured I had the wrong fan.
My rigs
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-498419
I am running Cougar Hydraulic-Bearing fans 120's and 140's, 16.6 and 18 DBA at max rpm which is 1200 and 1400, CFM is like 55 and 76.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/38529-quiet-case-fans/#findComment-499032
